how often should these be flushed
Old Nov 18, 2000 | 01:59 PM
bigdan17's Avatar
the power steering,power brakes ,and auto trans fluids.The place i go to have my oil changed always tells me that i need to haved them flushed when i change my oil.Is this right or are they screwing me over,in the nine months i ve had the car i ve had each system flushed three times,its not cheap for a 17 year old kid its run me close to 800 dollars . by the way its a firestone that does my oil
Old Nov 18, 2000 | 02:10 PM
Mo's Avatar
Mo
I know you dont need to change trans fluid that often,and i highly doubt you need to change power steering and brake fluid that often. I think I'd start changing my own oil from now on, or atleast find a new place to go.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
ede's Avatar
ede
i'd say most people never do it with no bad results. i'd learn to change my own oil too. for the correct service intervals check your owners manual if you have one or a repair manual.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 18, 2000 | 02:14 PM
bigdan17's Avatar
yea i have a haynes manual i ll have to look and see what it says i just always took their word for it,what a mistake,do u think i should call corporate and complain
Old Nov 18, 2000 | 03:10 PM
SeanSullivan's Avatar
If you are just driving your car on the street for normal purposes you shouldn't need to flush the trans but once every 36000 to 72000 miles, depending upon which yr you have. The brake I do as a matter of course once a yr, since most people use DOT 3 fluid I would recommend it once a yr ONLY. changin your oil, well most of the books I've seen say 3000 miles.
Old Feb 5, 2002 | 11:21 AM
1984Firebird502's Avatar
Do you guys know what they use the flush everything out anyways? Is it some kind of chemilcle or sm4omething?
Old Feb 5, 2002 | 01:09 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
More than likely what they define as a "flush" is simply changing the fluid they can get out. If they have gripped you for this service three times in nine months, and have told you that you need this done every time you change your oil, you have a case for fraud. I would talk to the owner/manager first, and if they maintain that this is the way it should be, show them your owners manual that says otherwise. Tell them if they refund your money for services performed that were not required, you won't call the better business bureau.
I would also call the corporate office, and let them know that these folks are giving firestone a bad name.....
Let 'em have it with both barrels!!!!
sheachopper
Jul 31, 2019 11:27 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
84redta
Sep 19, 2015 09:58 AM
gta892000
Sep 16, 2015 12:40 AM
