400 aluminum heads on 383?
Old Sep 18, 2003 | 10:33 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Just a quick question...can you use heads that were on a 400 SBC on a 350 or 383 small block with the proper head gasket? I'm just worried about the steam holes in the 400 heads. Yes, the heads are worth it, ported AFR's
Old Sep 18, 2003 | 11:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yup. no prob.
Old Sep 19, 2003 | 05:43 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
As long as your are using a 350 head gasket, Your golden. If you are super worried, Aluminum is easy to fix. You could have the holes welded shut and just mill it back to spec.
Wait, no you cant, sell your heads to me....cheap :rockon:
Old Sep 19, 2003 | 08:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The steam holes don't hurt a thing. The head gasket covers them up. Consider them as being already prepped for future upgrades.
Old Sep 19, 2003 | 08:51 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Old Sep 19, 2003 | 06:03 PM
Kevin Gray's Avatar
Uhhhh,,,, it depends IF they unshroud the valves on the heads,, and to what bore they took it out to. IF,, they took the chambers out to 4.155” to mimic a .030 over 400’s bore,,, I’d use the typical "400 gasket" (4.190” – 4.200”). If there’s a little core shift, a typical "350 gasket" (4.166”) might not seal the chambers. Chances are they’re standard 4” chambered heads with just the steam holes drilled and in that case the “350 gasket” would work – I’d definitely check them though!
No need to worry about the steam holes. They’re nonexistent on a 350 block and it doesn’t matter if the gasket you use has steam holes or not.
Old Sep 19, 2003 | 10:09 PM
dhirocz's Avatar
Cool! That's all I needed to know; I thught they'd work but wanted to be sure since I never considered doing it before. Thanks for all your help!
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
