alternator making noises
Old Sep 21, 2003 | 02:51 PM
SX Stinger's Avatar
Car: 84 Z28 "Holly" (SOLD)
Engine: Carbed 305
Transmission: TH350
This has only happened a few times and it goes awa y after a while. My alternator makes a "rattling" sound. It sounds similar to baseball cards in bicycle spokes. When it happens it only does it at idle or when I am slowing down to stop or for traffic etc., I have cheked to make sure nothing is in the fan or loose and evrytime I have checked it is coming from the alternator. Does anyone have any answers as to why/ what could be causing this??
Tahnks Drew
Old Sep 22, 2003 | 10:49 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: alternator making noises
Tahnks Drew
The alternator might have snapped a band, what is you're voltage reading?
Also, just curious.... check to see if you're harmonic balancer is rubbing up against you're timing chain cover.
Old Sep 22, 2003 | 11:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I had one that used to do that.... it would do it when I shut the engine off, in fact it woudl keep doing it for a second or 2 after the alt stopped..... very perplexing.
Turned out, there's a ring of steel wrapped around the windings of the armature, that's kind of swaged in place. Mine had worked loose and was free to spin around the armature. It made a weird scraping, rattling kind of noise. It didn't affect the working of the alt, all it did was drive the owner nuts, until I finally broke down and took it apart to see where that noise was coming from.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
