strange rpm problem on the high way
Old Sep 22, 2003 | 10:05 AM
icebird_1981's Avatar
yesterday i was on the high way and at limes i would go a lil hard on the gas just because i luv the speed lol, anyway i was almost there and the rev started to drop a lil then go back up like she was going to stall but she never did. it happend about 7 times. when i was comeing home i drove the speed limit because i was a bit worryed and it never did it.
my temp gauge does not work so i dont no the temp.
i got a 1983 z28>>carbed 350.
any help would be great i am a bit scared to drive on the high way now.
Old Sep 22, 2003 | 10:55 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: strange rpm problem on the high way
It sounds like either a drop in (or too little) fuel pressure, or a very weak ignition.
Old Sep 22, 2003 | 12:37 PM
how would i check to see if i have a weak ignition??? what should i replace?
Old Sep 22, 2003 | 12:46 PM
What kind of Carb are you running, and what is you're fuel pressure?
As for the ignition, is it stock? If it is, replace all of it. Replace the coil, module, wires, plugs (gapped properly), pretty much all of it.
Just double check you're fuel pressure though, as something (either fuel pressure, or spark), is not keeping up with engine RPM.....
Old Sep 22, 2003 | 12:53 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Weak ignition, there's a safe way and a cheap way to test it. The cheap way is to pull a spark plug wire off of the plug, and connect it to a screwdriver. Hold the screwdriver by the plastic handle and hover the metal of the screwdriver over, very close, to the fender while someone cranks the car over, and watch the spark. If it's any color besides blue or white, you need a new ignition coil or the plugwire, cap, or rotor is bad. Most likely a coil. Blue isn't the best color, but blue is acceptable. White is what you really want.
The safe way is to buy an HEI ignition tester. They're sold at auto parts stores...Advance doesnt carry one here, but Autozone does. Look by the diagnostic tools. To use it, disconnect a plug wire off the plug, and clip it onto the tester. Attach the wire off of it to a good solid ground. Turn the dial to the proper amount of gap. Again, have someone crank the car and watch the spark.
Old Sep 23, 2003 | 10:42 PM
i have a holley 750 VS carb, it was just rebuilt like 2 months ago.
i am gunna try to check the spark tomorrow for the colour.
i dont no my fuel pressure i am prob gunna go get some tool to check tomorrow.
i replaced my plugs and wires 2 months ago
but i think the problem is something with my coil, because a couple times she just stalls out on me and wont start back up for a bit. this only happen like 3 times, but i think this problem is related to this one.
should i grab a acccel coil?
Old Sep 24, 2003 | 12:34 PM
Nixon1's Avatar
Grab whatever coil ya want, but I recommend Accel or MSD.
Stalling and refusing to start doesn't sound like a coil problem to me, it sounds like your ICM is overheating.
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 17, 2015 02:52 PM
