My new engine
Old Sep 22, 2003 | 06:46 PM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
My new engine
Heres my engine combo. You should see the torque curve on this baby!
3.484” stroke nodular iron crank
5.7 forged big beam rods with ARP bolts
Hypereutectic flat top pistons at 9.0:1 compression
8” harmonic balancer
Hydraulic flat tappet cam with .480” valve lift, 230° duration @ .050”, 286° advertised duration, ground on a 108° lobe center
76cc heads with 2.02”Int/1.600”Exh swirl polished stainless valves with undercut stems for better flow; 1.250” high performance valve springs set up to match cam
Double row timing chain set
High volume oil pump with welded big pick-up screen and steel drive shaft
Edelbrock Performer RPM Aluminum intake manifold
Chrome oil pan
Chrome valve covers
The Torque curve is almost flat on the dyno we checked it on. its pretty cool. So what do you think of the combo? Its pretty sound!
I know if would benefit from a better stall and new gears, but that'll have to come later!
cheers!
Old Sep 22, 2003 | 06:56 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i take it you are using a carb? what size?
Old Sep 22, 2003 | 06:57 PM
x_wolf's Avatar
Car: 91 Camaro RS
yah, 700 CFM edelbrock man choke.
cheers
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
