LT-1 beating engine combinations
Old Sep 22, 2003 | 10:26 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
What kind of engine combos do you guys run to take on Lt-1's. Please post cause I am about ready to upgrade.
Old Sep 23, 2003 | 01:40 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
what exactly is an LT1???
stock Lt1??? modded??? you need to specify.
To beat a stcok LT1 all you need is basic bolt ons.
To beat a bolt on modded LT1... you are going to need a cam, possibly heads, and something to get more air flowing through the TPI, like a STealth ram etc.
Check out the guy with the Vortec headed TPI motor, I think his username is 1Bad91Z.
For under $1,000 dolaars you can do a cam, Vortec heads and Scoggin dickey intake and get over 340-350 hp.
Old Sep 23, 2003 | 10:46 AM
Car: 89 camaro RS
oh and my 350 is a carbed engine it originally was a v-6 but I swapped it out.. I want to be able to beat an LT-1 with the basic bolt on parts. I already have an edelbrock intake and carb.
Old Sep 23, 2003 | 11:56 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Re: what exactly is an LT1???
Why so cheap??
Old Sep 23, 2003 | 01:44 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
What type of intake? A Performer is nearly a stock replacment manifold, a 600cfm edelbrock is probably too small if your running around sea level. What gear ratio do you have? What type of cam do you have?
I was keeping up and sometimes beating stock LT1's with a 305, 600 holley, MTC-1 cam, action+ intake and 3.42's.
colton_carlson
Mar 8, 2019 12:21 PM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
cRoe4
Aug 7, 2015 08:46 PM
