Overfilled crank case??
Old Sep 23, 2003 | 02:56 PM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
Yesterday I changed the oil in my '89 to get it ready for winter storage and today when I checked the oil level on the dipstick it showed a high reading. The level was just over the arrow pointing down on the dipstick. Is it okay for this to happen??
Old Sep 23, 2003 | 03:05 PM
rezinn's Avatar
Hopefully it's just something you overlooked before. As long as there is no gas or coolant in it, you should be fine. Just watch for those things.
Old Sep 25, 2003 | 09:18 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
should be fine! i have overfilled a little a couple of times!
if there gets to be too much oil pressure the pcv valve should releive the pressure...
Old Sep 25, 2003 | 11:11 AM
1BadGTA's Avatar
Engine: 5.7 Liter
Cool thanks, yeah I dont' normally check the level that soon. And I let it all drain out until it drips, and put exactly 5 quarts in so I'm sure it's not a big deal.
Old Sep 25, 2003 | 11:17 AM
Steve89GTA's Avatar
5?, I can barely fit 4 sometimes.
Old Sep 25, 2003 | 11:32 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
dude on these cars you should check the oil like once a week when you fill up for gas!!! back a few years ago my cousin blew his engine in the trans am because he only checked like once a month and when he did he forgot to wipe the dipstick off then check the oil!!! so he thouight he was good. then one day pllwlwlwleelelflfcbvjffjkjkdjksd with a few @#$$%# @#$#$% @## and lots of money!
Old Sep 25, 2003 | 01:51 PM
Steve89GTA's Avatar
Ok, let's set this straight. I usually check the dip stick when the engine is completely cold (before going for a boot). Is this oK?
I also know that it has been said that you should check the level when it is warm...
Old Sep 25, 2003 | 02:22 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Checking the level before you start it will give the best reading in my opinion. Checking when it's warm is fine as long as you give it time to drain, but I like to check it when it's been sitting for a while.
Old Sep 26, 2003 | 06:39 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
yes it is best when it is sitting for a while!!! but sometimes it is not convieniant so you pump your gas you go pay piddle around in the station for a few then go out and check your oil... this gives it time to go back into the oilpan
Old Sep 27, 2003 | 02:46 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Actually, it only takes about 20 seconds for all the oil to drain back down into the pan. Anything that doesn't come to the pan in that time, isn't coming.
If it took a few minutes for it to drain back, your engine would suck the pan dry in about a minute or two... then you're really screwed, lol.
Old Sep 27, 2003 | 09:01 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
PCV valve has NOTHING to do with oil pressure, unless the engine was filled all the way to the top of the valve covers, then it might suck some of it out!!! But if that was the case I don't think the engine would run.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
skinny z
Oct 5, 2015 06:23 PM
Nikole
Sep 24, 2015 08:12 PM
