need to plug a leak....
Old Sep 24, 2003 | 10:01 AM
jeffsz28's Avatar
i installed a trans cooler on my 94 z28 and i bypassed the line into the radiator for the factory trans cooler and the open line drips little drops on the ground from fluid still stuck in the line. i tried to glue a bolt in the hole but still found a way to seep out. anyone have any ideas as what to use to plug up the end of the line. thanks Jeff
Old Sep 24, 2003 | 10:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Blow the fluid out of the lines with compressed air.
Put a fence at the top of the cliff instead of an ambulance at the bottom.
Old Sep 24, 2003 | 10:23 AM
jeffsz28's Avatar
don't have a air compresser-
Old Sep 24, 2003 | 10:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Use your biological one. Extend it with a piece of rubber hose if it doesn't reach.
Old Sep 24, 2003 | 10:42 AM
jeffsz28's Avatar
alright i will try that thanks
Old Sep 24, 2003 | 11:29 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
When you hooked-up the cooler; did you simply re-route the lines that normally go to the radiator and run them to the cooler instead? Are the nipples on the radiator what's leaking now?
If so, there's a better way .
Run the pressurized cooler line (from the tranny) to the cooler, then from the outlet of the cooler into the radiator where the pressurized line used to connect.
This serves two purposes: Extra capacity, and it keeps the tranny oil from getting too cold since the radiator will heat the fluid if the cooler overcools it (like on a cold day). The tranny likes warm fluid, if the fluid becomes too cold, it doesn't flow as well thru the tranny. Slow fluid flow inside the tranny will cause increased wear due to slippage during shifting.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
