I'm throwing Code42 and 43. Can this be the reason....w/in
Old Nov 22, 2000 | 12:29 AM
Mike '91 Z28's Avatar
Code 42. Fault at electronic spark timing circuit
OR
Fault at direct ignition system
OR
Fault at fuel cutoff relay circuit
Code 43.
Low voltage at electronic spark timing circuit
Can this be that I have my distro in one tooth off?
Old Nov 22, 2000 | 09:07 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
You did plug the tan and black computer bypass wires back together after setting the intial timing didnt you?
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
okfoz
Oct 13, 2015 02:19 PM
racereese
Oct 3, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
