Oil pump - high volume or no?
Old Sep 25, 2003 | 11:02 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I'm rebuilding a 350 for the 92 car and am curious if I should get the high volume oil pump that comes with the federal mogul rebuild kit or specify that I want just the standard oil pump. The engine will be a mild one with tight clearances (lpe 211/219 cam, pro topline 180's and tpi)
Old Sep 26, 2003 | 01:08 AM
Morley's Avatar
No, get the standard pump. H/V pump will empty your oil pan during hard acceleration.
Old Sep 26, 2003 | 02:45 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres no need to try to pump extra oil in there.. athough if you did, you would have to have better then normal drainback.
it would also put uneeded stress on your distrib(and in turn the cam and timing chain)
you dont need it for this motor, it wont help anything, and you would be putting uneeded stress on the distrib.. just get the standard pump with the standard pressure spring...
Old Sep 26, 2003 | 06:01 AM
ede's Avatar
ede
use melling m55 with the mr gasket #26 spring and weld a brace from to the pick up and bolt it to the pump body
Old Sep 26, 2003 | 07:49 AM
BILLY SMITH's Avatar
use a stock big block chevy pump. we use them on a lot of our asfault cars with stock pans very good .if you look at the housing on your small block pump it has 4 bolts on the plate where your gears are , the bbc pump has 5 bolts there are more teeth in the bbc pump to. volume is fine in a stock pump but you need a little more pressure bbc has that.......as long as you maintain at least 10psi per thousand rpm you will be ok .....Ex if you turn 5000rpm you need 50 psi
Old Sep 26, 2003 | 03:21 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I did exactly as Ede mentioned (M55 pump ands a #26 spring).
At idle with a hot eng, I have 25 psi.
Cruising thru town, I have abt 45 psi.
At highway speed I have 60 psi.
BTW, that Mr Gasket spring is rated at 60 PSI.
FWIW, Lingenfelter recommends this set-up for all SBC street engs.
Old Sep 26, 2003 | 10:36 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Since the Mr. Gasget spring is rated to 60 PSI, have you ever noticed your pressure go above 60 when racing or really tearin around town? Also, what do you mean by welding a brace from the pickup and bolting it to the pump body? What exactly does that do, and how do you know where to get it welded to? I'm going to be rebuilding my SBC which should be pushing about 420-430 HP, so do you think the M55 with the High Pressure spring would still be a good route to take?? Atleast it isn't an expensive setup.
Old Sep 26, 2003 | 10:44 PM
_max_'s Avatar
btt
Old Sep 26, 2003 | 10:46 PM
Stingraye's Avatar
Car: 1986 Trans Am
what? What was the ?? for?
Old Sep 27, 2003 | 10:29 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
With a cold eng, the oil press is over 60 PSI., but I also have my oil filter bypass valve plugged off, so that may make it a little higher than normal.
Once the oil temp comes up, the spring regulates the oil press to ~60 psi up to at least 5K rpm (haven't been past 5K yet).
The oil pick-up tube (strainer) is a pressed fit into the pump, and they occasionally fall out. The brace mentioned before, keeps the pick-up tube from falling out (or twisting) of the oil pump and starving the eng for oil. I brazed my pick-up tube straight to the pump.
To find exactly where to weld the pick-up tube:
Install the pick-up tube. With eng upside-down, place some modeling clay on the pick-up tube, and install the oil pan. Remove the oil pan. The clay will have been squeezed between the oil pan and the pick-up tube. Keep adjusting the tube till you have 3/8" clearance, then weld/braze it.
IMHO, this set-up will be fine for your engine.
Old Sep 27, 2003 | 09:57 PM
_max_'s Avatar
ZZ28ZZ ANSWERED IT "what? What was the ?? for?"
Old Sep 28, 2003 | 07:51 AM
ede's Avatar
ede
i don't like welding to the pump cover, but i know many many people do with no problems. i prefer to bolt to the pump and weld to the pick up tube
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
BBSDesigns
Aug 11, 2015 07:39 PM
