Valve spring questions
Old Sep 26, 2003 | 09:09 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Ive got AFR heads with the stock valvesprings they send. My cam is a 503 Xtreme grind. 224/230 dur and 503/510''. My valves are starting to float around 6300-6400. I will be switching to a LT1 intake soon and now I will want to turn more. First off anyone know the specs on my stock AFR springs and what springs are people using with no valve float on a higher revving car with a cam similar to mine.
Chris
Old Sep 26, 2003 | 12:15 PM
Vader's Avatar
Since you're a customer, they should be glad to answer your questions if you call or email.
Old Sep 26, 2003 | 12:43 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
wow, your reving it awefully high for a cam that size... i run a xr288 cam- 110lsa, 236/242dur @ 050, and 520/540 lift, and i make peak power around 6100...
comp has a roller spring package, those are the biggest springs you can put on a hydrolic roller lifter before you need a rev kit to extend the rpm range or solid lifters...
Old Sep 27, 2003 | 07:55 AM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Use comp roller spring package with valve springs 987-16. These springs are good to .550 lift if installed at 1.75.
Old Sep 27, 2003 | 09:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I agree, 987s would be a good choice and will fit the heads directly. The K-Motion garbage that AFR puts on their heads is your problem. I wonder when they're going to wake up and realize that the one single thing that upsets people the most about their product is the crappy valve springs they put on them.
gta90
Sep 15, 2015 04:00 PM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
