Which tool to use?
Old Sep 27, 2003 | 02:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Which tool to use?
Lower A-arm bolts, rusted into the sleeves. Which tool do you use?
Bolts won't turn with a wrench or move when hammered on. Don't care about bushings (reason bolts are being removed). Short of a torch, what is the best way to remove the bolts and drop the A arm out?
Thanks,
RBob.
Old Sep 27, 2003 | 03:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
cutoff wheel
Old Sep 27, 2003 | 04:46 PM
ede's Avatar
ede
torch would be a good choice along with a BFH
Old Sep 27, 2003 | 04:56 PM
OMINOUS_87's Avatar
3-foot section of pipe on the end of your ratchet. That was my method as i ripped the entire suspension from my beast. Funny thing was that none of the bolts ever broke, go figure. Dont forget a big old can of WD-40.
Old Sep 27, 2003 | 05:29 PM
RP1987GTA's Avatar
get some PB blaster in a can....its a special rust penetrant that will loosen anything rusted.
Old Sep 28, 2003 | 07:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Appreciate the input(s). Time to hit Harbor Freight.
RBob.
92projectcamaro
Dec 8, 2015 12:25 AM
tyeo098
Nov 30, 2015 06:27 PM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
