jumpy Tach on my 88 TPI...
Old Nov 24, 2000 | 09:21 PM
zachs's Avatar
Hey guys...
I just got my car back from the shop (starter wiring problem), and drove it for a few days. This morning I got in it, and fired it up to warm it up. I let it idle for a while, and came back outside and took off to go to work. As I got on the highway, I set the cruize at 61-62 mph. I looked at the tach, and every once in while, it would jump up like 50-150 rpms. No difference in the engine speed/exhaust tone, and I am at a loss. Anybody have any ideas?
thanks a ton in advance!
ZachS
Old Nov 25, 2000 | 12:29 AM
Vader's Avatar
Zach,
Time to start looking at connections at the distributor. Make sure the wire on the "TACH" terminal at the distributor is solidly connected and the ignition primary wires are not routed too closely to the ignition coil. GM had a TSB on this problem and recommeded moving the wiring as far away from the coil as possible.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
