Timing Adjustments
Old Nov 24, 2000 | 08:59 PM
Omar's Avatar
Timing Adjustments
It's been over a year since I have done this, and i cant believe i have forgotten this already. Is 6 BTDC above (towards the passenger side) of the 0 mark, or is it below it(drivers side)on the timing tab? And counter-clockwise on the distributor is advancing, right? I gotta set it at stock specs for my smog test.
1989 IROC-Z 5.7L
Old Nov 25, 2000 | 12:24 AM
Vader's Avatar
Omar,
Since the engine rotates clockwise as viewed from the front, advanced timing would occur sooner, or toward the passengers' side at the timing marks. The underhood VECI label should have the diagram and specifications. And yes, the distributor rotates clockwise as viewed from the top on SBCs, so advancing the timing would require turning it in the opposite direction.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Nov 25, 2000 | 12:55 AM
Omar's Avatar
Thanks Vader!
1989 IROC-Z 5.7L
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
