timing on a 305?
Guest
Posts: n/a
timing on a 305?
yes, somebody said that it is 6 degrees spark advance.
i'm at 10 and sometimes feels like i'm detonating, and worst i'm doing this for years and years! can somebody please bring some light to my ignorance?
the engine is a 1979, tiny puny stock 4 barrel 305, ex olds 79. (cutlass i think)
thanks everybody.
thanks everybody.
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Yeah 10 is way too much. 6 is alright. I accidentally set the timing at 12 after my last tune up. I guess I had no detonation because the plugs were new but I backed it off to 6* the day I found out. Throttle response obviously went down but at least the motor will live longer.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
Accel cap and rotor
Was on a dyno yesterday, started at 4* advance on timing. Shifting at 5500 rpm 1st thru 4th I got 177hp, when I reset the timing to 5 1/4* I got 185hp. I wouldn't have thought that little of a timing change would make a difference, it did.
FSG,
Every engine is different. My 45,000 mile 305 TPI runs well at 10½° BTC, as indicated by the balancer ring. Since the balancers can't always be trusted, you really have to play with the settings and use the marks as a reference point. I start to get excessive retard when I get closer to 12° on 94 octane elthanol blend.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
Car: Take
Engine: Your
Transmission: Pick
I get a max of 9* of spark retard during WOT runs with my timing set at 6* BTDC, which isn't good, but then haveing the wrong knock sensor isn't helping me. Either that, or the outerring on the balancer isn't right.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I was playing around with mine last night, it was originally at 6. I bumped it up to 10 and it really made a difference. I had a surging problem at WOT and that is now gone bye bye. I can hear just a hint of detonation when running about 2/3 throttle, but normal driving is fine. I think I'm gonna leave it!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
Guest
Posts: n/a
thanks to everyone for your info.
i did set it back to 6* and runs real smooth, but doesn't have the previous quick response, don't get me wrong, is still good and it was detonating at 10*, maybe i should try those aftermarket springs for the distributor flywheels, i think they'll compensate by allowing the timing to reach the top sooner, do you think so?
thanks again.
thanks again.
My old lg4, after it was worked over a liyttle (cam, heads, intake) liked 14 degrees of initial
1987 .030 over lg4
too much wasted money
best slip: 14.000@98.7
and it's quicker now.
1987 .030 over lg4
db057
Aug 11, 2015 10:11 PM
