CAR takes too long to heat up.......PLEASE HELP
Old Nov 25, 2000 | 12:54 PM
IROC86's Avatar
i dont know what it is but ever since it started gettin colder, my car is having a real hard time heating to closed loop. It will never ever run over 180 not even in the high 90's it was in the summer. and now im struggling to get it to go to a little bit past hundred. The choke comes on and then all of a sudden it freaks out and starts idling at 2000 throws a SES and when i push on the gas it goes back down. WHat is wrong guys?????
Old Nov 25, 2000 | 01:25 PM
crazeinc's Avatar
sounds like it's cooling so well it's too good...throw in a 190* thermostat (if you have changed it) and see if that helps.
Old Nov 25, 2000 | 04:42 PM
82z's Avatar
82z
It sounds like your thermostat is stuck open.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
