Fuel Fiter clogged?
Old Sep 30, 2003 | 08:57 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Fuel Fiter clogged?
im still working out the kinks with my new motor, now the carb isn't getting any fuel. there is fuel on fuel pump side of the fuel fiter, but on the carb side of filter, nothing. i bought a cheapo chrome 5 dollar inline fuel fiter, and it seems clogged.
can i run the motor for a few minutes without it?
isn't there a fuel filter in the fuel line further back near the tank
Old Sep 30, 2003 | 10:51 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
alright thats not it..... the fuel pump isn't pumping jack. i poured a little gas into the carb and got it to fire, and the fuel pump isn't doing a damn thing.
it is a holley, mechanical, brand new. it has only 2 threaded ports on it and one port that isn't threaded, and looks like it is blocked off on the inside. it is the farthest one to the left. im using the middle one for the fuel from the tank, and the right one to the carb. but the fuel pump documentation didn't say which port is which, and it doesn't say on the fuel pump so i have no idea.
i think im going to hook up the stock one and see if i can't get the motor running for right now.
but this is just pissing me off...
the motor was running last night for like 20min
and then it just started to cut out, now it won't start.
and i syphened fuel out of the line. and im getting feed up with this thing
Old Oct 2, 2003 | 02:13 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
are you sure the pump is getting power to run it? Checked fuses/fusible links?
Old Oct 2, 2003 | 04:52 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
DUDE! Holley Mechanical pumps don't use electricity!
Old Oct 2, 2003 | 06:07 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
DUDE
I had a holley pump and it did, bro.
I didn't read it was mechanical, my bad, dude.
Old Oct 3, 2003 | 07:03 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Go up and read it again! He said "It is a Holley, Mechanical, Brand new. I didn't say Holley didn't make Elect. fuel pumps! I rest my case. We don't even know what he's working with here. Could be a farm tractor for all we know! Didn't mean to **** you off! I apoligize. Back to his problem! I would make sure that their both the same first, some had long arm, some had short! Could even be a bad pump. The pump should be marked inlet outlet Or an arrow at least. Seems odd that the old pump worked and the new one doesn't.
Glowsock
Jul 24, 2025 03:15 PM
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
