Replacing Valve Seal?
Old Oct 1, 2003 | 04:21 AM
RS91's Avatar
Because of all the smoke that my car is blowing, I'm getting ready to replace my valve seal. The smoke is like bluish color it smells like unburned gas comming from the exhaust. Can someone give me a list of all the thing I need and the tools needed to do this job. If you have any other recommendation your help will be greatly appreciated....Ohh by the way part no will be great too....
Old Oct 1, 2003 | 11:17 AM
ede's Avatar
ede
basic hand tools, head on engine valve spring compresser, air compreser, dial caliper. little trick i have is to measure the distance from the top of the stud to the top of the nut with the depth rod on a dial caliper before i remove a rocker so all you have to do is replicate the measurement when you reinstall it
Old Oct 1, 2003 | 12:01 PM
kevinc's Avatar
Car: 1982 Z28
I think you just made his head explode...
Old Oct 1, 2003 | 01:28 PM
ede's Avatar
ede
kevin that's something i failed to take into consideration, but you may be right
Old Oct 1, 2003 | 04:45 PM
RS91's Avatar
That's it! Thanks for all the info. You know a good site where to order the seal?
Old Oct 1, 2003 | 06:13 PM
ede's Avatar
ede
most of the parts stores have on line ordering or any of the big preformance dealers, try auto zone, advanced auto parts, jegs or summits web sites
Old Oct 1, 2003 | 06:14 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
You will also need an adapter to screw into the spark plug hole to connect the compressed air to. Also, a good repair manual helps explain the whole job.
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Aug 6, 2015 04:15 AM
