What to torque oil pressure sending unit to and sealer questions
Old Oct 2, 2003 | 12:53 AM
25THRSS's Avatar
What are the torque specs for the oil pressure sending unit on a 92 camaro with a 305 tbi. It is the one above the oil filter. Also, are you supposed to put any sealer on the threads?
Old Oct 2, 2003 | 05:16 AM
ede's Avatar
ede
it's NPT, no torque spec either tape it or use liquid teflon
Old Oct 2, 2003 | 12:25 PM
25THRSS's Avatar
What does NPT mean? Where can I find liquid teflon?
Old Oct 3, 2003 | 01:34 AM
25THRSS's Avatar
ttt
Old Oct 3, 2003 | 12:06 PM
Damon's Avatar
NPT: National Pipe Thread. It's a tapered thread so it gets tighter the further you screw it down.
Torque spec? Think: "sparkplug tight", not "gorilla tight." It doesn't take a whole lot to prevent a leak and you do NOT want to strip it out. Absolutely no way to get in there and repair it with the engine in the car. You can always start a little loose and tighten further if it's still "weepy."
If you have a new sender it should already come with some thread sealer applied right out of the box. Liquid teflon can be purchased just about anywhere you can buy engine assembly parts and tools. A good local auto parts shop, an engine shop, even from Summit and other mail order places
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
