rear main oil seal
Old Oct 2, 2003 | 11:54 PM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
rear main oil seal
is the rear main oil seal on my 90 5.7 a two piece or one piece???
thanks....
Old Oct 3, 2003 | 12:15 AM
nathan2003's Avatar
Car: Camaro
oh **** schwan are you a gimp or what... come on get with it... its 2...
actually j/k don't know just playin with ya schwan... you should know that answer... look her up in your bird book you can't afford to replace it anyways... later man..
-vetter
Old Oct 3, 2003 | 01:11 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If it really is a '90 5.7, it's a 1 pc. rear main seal.
Look at the casting number, then go to www.Mortec.com just to be sure it's the block you think it is.
Old Oct 3, 2003 | 10:26 AM
strokedtpi's Avatar
Engine: 5.7
ok im sure of what it is so it must be one of those dang 1 piecers huh...well thanks for help...ive been noticing a little bit of oil around my flywheel cover and on the front side of the tranny so i just thought i would ask before i even started thinkin about it..thanks
oh vetsky i tried the books..haha
Old Oct 3, 2003 | 11:42 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
86 and below are 2 piece 87 and up are one piece
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
