Cylinder heads...
Old Nov 27, 2000 | 10:07 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Cylinder heads...
If I were to install 1.94 intake valves in a set of '84 L-69 heads, would they flow as good as a set of stock 350 heads of the same year ?? They would be installed on a 350 (NOT a 305)...Also, what size are the cumbustion chambers ??
Old Nov 27, 2000 | 10:48 PM
Vader's Avatar
T.L.,
Get the casting number from the rocker area (under the cover) and check it at Mortec.com. You should be able to get a chamber size there.
The heads probably don't flow as well as stock L98 heads, and the larger valves might help but the port sizes may be smaller. If you don't change the exhaust valves, it would hardly be worth the trouble. Stock castings can be ported to flow better, and can be deep-ported if you want to add some filler weld.
By the time you're done, you might have several hundred dollars in the heads, and you might be better off getting a used pair of L98 heads as a starting point, prep them, them perform the swap.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
