Freon help
Old Nov 25, 2000 | 08:07 PM
dtpmike's Avatar
Freon help
Hey I jsut installed a new compressor and accumulator. Not sure which valve to put the freon and oil into. The valve off of the accumulator or the valve on the pipe next to the accumulator. I have an 89 camarol.
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from MrMikes.com
Old Nov 25, 2000 | 08:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The "yellow" hose will only fit on one of the lines, which will be the one on the accumulator. The other fitting will be to small.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
ede's Avatar
ede
the low preasure side ,the big line.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 25, 2000 | 10:13 PM
dtpmike's Avatar
well I hope you guys are right. I am going to put freon and oil in the valve on the accumulator.
Old Nov 26, 2000 | 08:07 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You don't trust our experience? Go take it to some hole-in-the-wall shop so you can pay out the nose so they can screw it up for you.
I wouldn't have posted it if my techniques were not to GM standard.
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
[This message has been edited by GMTech (edited November 26, 2000).]
Old Nov 26, 2000 | 11:20 AM
Pat Hall's Avatar
While you're at it, since you replaced both the compressor and the accumulator, I'd retrofit the system to R-134a. It's a lot cheaper for the freon, and you can buy it off the shelf at the parts store.
Old Nov 26, 2000 | 09:06 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
If you replaced the compressor and accumulator, did you also flush it out? You prolly need a new orfice tube. The 134a conversion is also an excellent idea at this point. Make sure you also add the proper amount of oil to the componenets that you changed!
BTW.. GMTech...Some of those small shops are pretty good. I like to think the one I work at is, in fact we ocasionally fix stuff some of the local dealers have messed up! Factory training is awesome though, that's what I miss about working at the dealership!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Nov 27, 2000 | 08:57 AM
dtpmike's Avatar
yeah I did switch to r34a. The problem is that the kit sucks. I screwed it on as tight as it would go and it leaks. Then I realized that you have to have the AC on when you aer puttign the freon and oil in right? Well I got like 1.2 bottles of freon in and hardly any oil since teh leak. Am I doing this correctly?
Old Nov 27, 2000 | 11:50 PM
Russ-So Cal's Avatar
You need to get the oil in there. If you run it without the oil, you'll "lunch" your new compressor. I'm not sure what sort of propellant if any is in the oil can, but you have to get the oil in the compressor.
Old Nov 28, 2000 | 12:03 AM
JP84Z430HP's Avatar
Car: 84 Z28
Oh, those 134a conversion kits really do suck! I've gone through quite a few at the shop, and about half of the oil dispensers fail. I've saved a couple of the good ones and pour the oil out of the bad ones in to the good ones and get it in there that way. I am assuming that you're talking about the type that takes a socket to thread a screw in to push the oil out.
Next thing is that you should also add some oil to each component you replace. There is a standard amount, and I'd have to look it up since we haven't been doing A/C lately (it's just too damn cold here to worry about it!) I think the compressor takes 4 or 6 ounces, and each other component or line takes 2 ounces. Like I said, I'm not sure.
So, how does the compressor sound? Is it abnormally loud? If it is, quit using it until you can get some oil in it!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
BigWhiteGTP
South West Region
Mar 10, 2005 04:39 PM
ScrapMaker
May 6, 2004 09:14 PM
jaredjames
Mar 8, 2004 03:41 PM
manchesterbeast
Jan 1, 2004 08:09 PM
soulbounder
Nov 25, 2001 03:30 PM
