mechanical pump or not
Old Oct 4, 2003 | 02:08 PM
icebird_1981's Avatar
hey guy, hopeing u could help me out here. i got a modded 350 in my 83 z28 and i find that around the mechanical fuel pump ring there is some gas some how leaking out pluse the gasket is leaking. my questions is what r the symptoms of a mechanical fuel pump going??? i got a holley 750vs carb on a holley contender intake should i up grade my pump since my car is modded? does it make a diffrence??
thanks
Old Oct 4, 2003 | 07:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are basically two symptoms of a mechanical pump that's about to go out: 1) It doesn't maintain pressure; 2) It leaks.
Leakage can be either internal (leaks into the crankcase, contaminating the oil), or external (leaks to the outside). Neither is good.
Old Oct 4, 2003 | 09:12 PM
thanks for the reply. so i guess i do need to replace it, i have one from a lg4 could i use that on my 350?? or what after market one would work best, i have a late 70s 350 carbed. thanks
Old Oct 4, 2003 | 10:17 PM
five7kid's Avatar
The advantage the LG4 part would have is it has a return port. Helps keep the fuel cool that's going to the carb. If it is in good condition, it should feed the engine just fine.
Carter & Holley both make decent aftermarket performance pumps. But, I'm doing fine with an AC replacement on the Camaro.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
