Not Firing, Not Injecting Fuel- WTF Over
Old Oct 4, 2003 | 06:01 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
The car has no fire from the coil. All 4 wires on coil are hot with a test light. The injectors aren't spraying fuel. I've got an injector test light hooked up and it don't flash when turning over engine. I've tried a new coil(even though the old one tested good), I tried a used ECM from a junk yard. I've checked all fuses and fuseable links. The ECM shows no codes other than 12. I've looked for wires that might be lose for hours and found none.
The car was fine untill I changed the valve seals, and after that it won't start. The valve covers were off and I took the distribtor cap off to check for #1 & 6 TDC. I'm losing my mind over this now. What would cause the car to not fire and not to pulse the injectors? Please help, Bobby
Old Oct 4, 2003 | 06:38 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Pick-up coil?
Old Oct 5, 2003 | 10:20 AM
chevypower's Avatar
Going out to check it now. I found a page shoeing how to test the pick up coil! let you know the outcome later. Thanks, Bobby
Old Oct 5, 2003 | 10:37 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
a bad ign. module could also be to blame.
Old Oct 5, 2003 | 05:00 PM
chevypower's Avatar
Tested the pick-up coil and it showed 824(normal resistance is 500-1500) between the white and green wires. I got no resistance between the white or green and the distributor body as a ground. So I'd have to say it is good, that puts the ECM, coil and pick-up coil good. Only thing left is the ing. module. Dimented24x7 you think the ing. module would cause the injectors not to fire too? Auto Zone says they can't check the module, so I guess I'll just have to spend the $23 to find out. I'll let ya know how it turns out in 2-3 hours. Thanks, Bobby
Old Oct 5, 2003 | 08:13 PM
dnult's Avatar
In general computer controlled vehicles will turn on the fuel pump for a second or two when the key is turned on to prime the fuel system and then shut off. Then the ECM will wait for distributor pulses before turning on the ignition and fuel pump / injectors on again. In addition, some cars have a crank-shaft position sensor that works similarly. I don't know that much about the spefics of your model though.
Sounds like the computer isn't aware your engine is turning over so it's cutting fuel and possibly spark. I support other's theories that the ignition module or pickup is at fault. Sounds like you've ruled out the pickup.
-dnult
Old Oct 5, 2003 | 08:59 PM
chevypower's Avatar
Well it was the ing. module. Now on to finishing this project up. THANKS ALL, Bobby
RS Reaper
Oct 17, 2018 07:52 PM
NZKnight
Oct 15, 2015 02:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
