crank but no spark
Old Nov 27, 2000 | 11:50 PM
Floppysj's Avatar
crank but no spark
I have an 89GTA 5.7 ,here is the problem I was driving to work when all of a sudden the car died on me, tried to start it back up again and it won't. My car crank but won't spark. My freind told me i need to change my pick up coil module or my coil. Any Ideas what's wrong and how to fixe my car?I would really appriciate any of yor opinion.
Mike
89GTA
Old Nov 28, 2000 | 06:12 PM
ede's Avatar
ede
i'd listen to my friend and than ask here if that doesn't work out.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 28, 2000 | 06:38 PM
Vader's Avatar
Floppy,
Find out what kind of friend he/she is. Remove the HEI module and have your friend give you a ride to the auto parts store to have it tested (usually free).
While you're working near the distributor, measure the resistance of the pickup coil. It should be 500-1,500 ohms, and you should get no reading to ground (infinite). Check the resistance of the coil primary and secondary windings (should be 0.5-1.5 ohms and 6,000-15,000 ohms, respectively). Then check the resistance of the coil and spark plug wires. About 500-7,500 ohms per foot should be about right.
One of these should get you pointed in the right direction.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Nov 28, 2000 | 09:22 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
hey floppy I have been having the same problem for awhile now.
if you want you can read the other topic in here that i started but that only got me to reading what vader just said about testing resistance.
definately go check that module though because if you dont have a short then its a cheap part and you are done.
james
88 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
no MAF screens, no cat, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
homemade ramair.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
camarohelp
Sep 22, 2015 03:19 PM
