HELP!!!!car wont start
Old Nov 28, 2000 | 09:59 PM
kermit_one's Avatar
well first its an 89 iroc(not mine a friends)5.0tpi, auto, it will not crank,the starter is good, we hooked up a remote starter and it cranked fine,it has fire because when i pulled the plug wire off to check i got shocked pretty good,(haha not funny)i can hear the fuel pump with the key on,i checked the valve on the fuel rail fuel came out.whats up with this thing?key on,remote crank, spark, and fuel and nothing..
92RS,POLO GREEN
Old Nov 28, 2000 | 10:44 PM
Vader's Avatar
Kermit,
Does the friendly little yellow VATS light stay on or flash when you try cranking the engine?
Is the transmission in PARK? If so, try it in NEUTRAL.
Is the steering whell tilted all the way to the lowest position? The sector mechanism on the ignition switch linkage can wear so that the switch is not pulled far enough to engage the starter. Sometimes adjusting to the lowest position can take up a little slack in the linkage.
Is the solenoid functioning? If you used the remote to engage the solenoid, it should be O.K. You can also check fuses and fusible links.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
