timing chain-TDC-rotor
Old Oct 5, 2003 | 09:45 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
I was in the process of putting a timing chain on my 1992 z28 with 5.7 TPI and turned the motor by hand to TDC. When I removed the dist. cap the rotor was not pointing to #1 cylinder, it was pointing toward the drivers seat. Anyone know what the deal is?
Old Oct 6, 2003 | 05:03 AM
ede's Avatar
ede
on exhaust stroke not compression stroke, you want TDC, both valves closed and rotor at #1. when you install the chanin and gear set put them in dot to dot then rotate one time till both dots are straight up and set distributor and rotor to point to #1 post on the cap, or you can make any post the #1 post and connect plug wires accordingly
Old Oct 6, 2003 | 10:21 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
When you line up the timing gears dot to dot the engine is on the exhaust stroke, not the compression stroke. You will need to rotate the engine one full turn, then drop in the distributor, pointing the rotor to the # 1 tower.
Old Oct 6, 2003 | 01:41 PM
pigsticker's Avatar
Car: 1992 z28
O.K. I get it now. Thanks, you guys have been a big help.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
