Need Help, Car is Missing
Old Oct 6, 2003 | 08:09 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
ok my car just started to miss a few weeks ago. Could it be the crappy autozone brand ignition module I put on a year ago.
Old Oct 6, 2003 | 08:13 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
possibly....check all of your plug wires and plugs (ive had a plug wire fall off before...had a miss and couldnt figure it out because it was the number 8 cylinder and really hard to see) then check the resistance off of your injectors with an ohm meter they should be right around 16.8 i think but i believe anything above 12 is okay
Old Oct 7, 2003 | 07:37 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
If your car is missing, I'd call the police right away. :lala:
Old Oct 7, 2003 | 12:56 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Sounds most likely like an ignition problem to me. Ignition modules tend to either work completely or not work at all. Havent heard of one causing a miss or anything like that. As someone else said, check your ignition wires. Check your spark plugs, distributor cap, and rotor as well. Doesn't hurt to check your ignition coil output. Other possibilities include distributor gear wear, but that should have shown up before now, and a pickup coil going bad possibly. Does your tachometer act up?
Old Oct 7, 2003 | 02:39 PM
white91Z28's Avatar
Engine: TPI 350
yeah i can see the neddle jump
Old Oct 7, 2003 | 08:11 PM
white91Z28's Avatar
Engine: TPI 350
problem fixed it was the number 8 plug wire. Easly overlooked. it was barely on the plug....
Old Oct 7, 2003 | 09:56 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
yeah i had the exact same problem about a week ago.....my miss just got worse and worse as the plug fell farther off until it came right off....and with all the smog stuff in the way its not visible you have to give a tug on the wire to notice.
hectre13
Dec 11, 2023 08:14 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
