Maximum bore/stroke of a 350?
Old Oct 7, 2003 | 12:19 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
My friend's dad has a bada$$ Corvette Stingray with a worked over 350. It's got a stroke kit in it and it's bored out like crazy. My friend doesn't know exactly how many cubic inches it equates out to, but he's claiming somewhere close to 390. What's the maximum a 383 stroker can be bored to? I can say this....I DO believe it's at its maximum limit, because it's running a low temp thermostat, a 4 core radiator, DUAL electric fans, and never runs below 220 degrees.
Old Oct 7, 2003 | 12:22 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
A 350 block bored .060" over with a 3.75" stroke is 388 cid. That's pretty close to a 390.
Old Oct 7, 2003 | 12:26 PM
Nixon1's Avatar
Just what I needed to know! Thanks.
Old Oct 7, 2003 | 12:38 PM
bigals87z28's Avatar
Car: Check The Sig
you can get a 396 with a bigger stroke.
Old Oct 7, 2003 | 01:10 PM
ede's Avatar
ede
sounds more like a potential cooling problem, there is no corralation between temp an engine runs at and the bore or stroke
Old Oct 7, 2003 | 01:12 PM
Nixon1's Avatar
Really? I just assumed that since the cylinder walls were so thin that the engine would be prone to having cooling issues.
I bet he just set his electric fans improperly if that's the case.
Old Oct 7, 2003 | 01:23 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
usually the biggest stroke you can run(or would want to run) with a production block is 3.875", and i wouldn't want to run over a .040" overbore, .060" is asking for cooling problems.
but .040 over and a 3.875 stroke is 397 cubes.
Old Oct 7, 2003 | 01:24 PM
Car: Check The Sig
Yeah, could be that the fan isnt cooling right or something with the shroud... or it could be that bore is too big and the walls are thin. The heat transfer is great, but with all that cooling i dont know why its running so hot.
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
