long cranking
Old Nov 29, 2000 | 05:29 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
long cranking
hi,
sometimes when i start my car it cranks forever, but will start eventually. most of the time it starts right up.
it does it when the engine is hot or cold, so i don't think it is heat soak to the starter, plus it doesn't crank slow.
i'm thinking it could be the cold start injector going bad, or maybe an ignition problem.
any help is greatly appreciated!
88 CAMARO RS
87 IROC-Z DRIVETRAIN
305 TPI, 700R4, 3.73s
ported plenum, performance resource chip,edelbrock TES Headers and cat-back, K&Ns, AFPR, rest is stock.
15.0 @ 92.5 (bald tires)
Old Nov 30, 2000 | 08:00 AM
Mark W. Winning's Avatar
Most of our cars need oil pressure to hit a certain point before ignition is fired. My 91 and 92 RS's had this problem. In my case, when I turned the key on, the fuel pump was NOT giving you that short run to get fuel pressure up. One car had a bad relay, the other a bad brown wire from the fuse panel to the relay. Just a though..
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Nov 30, 2000 | 12:53 PM
bleak's Avatar
check fuel pump (does it whirr in a timely manner? does it sound weak?), fuel pump relay, and ignition! If you suspect the ignition, it's probably because you haven't worked on it! Your car will perform better with some new plugs and wires. Get a coil, rotor, and cap as well. They aren't expensive.
Old Nov 30, 2000 | 05:38 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Mark i have an unrelated question; Jeez a 383 toyota pickup, how the heck did you do that? Do you have any pics???
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
Old Nov 30, 2000 | 07:37 PM
Car: Damn
Engine: This
yeah the fuel pump sounds good. it always pressurizes the line with no problem, i checked with a fuel pressure guage. the plugs and wires are new. cap and rotor fairly new and in good condition.
what about the cold start injector?
88 CAMARO RS
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
