functional front grill
Old Oct 8, 2003 | 08:13 PM
AustinT's Avatar
Is it possible to open up the front grill on our cars and allow more airflow for cooling. I was thinking about adding a supercharger with a large intercooler. Any reason it cant be opened up?
Old Oct 8, 2003 | 08:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It can, but the problem is the rad is right behind it, and so is the AC coil.
Old Oct 9, 2003 | 01:56 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
True, cutting holes in the grill won't make a huge difference in cooling, but every little bit helps. Your best bet is just o make sure yuor air dam is in perfect shape and that your AC ccondenser is not all smashed up. Also, clean out the space between the ac cond and the rad real good. you get a good bit of leaves and stuff in there and that can raise your temp pretty good.
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
silverstang84
Exterior Parts Wanted
Sep 21, 2015 08:05 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
