Baro sensor circuit
Old Oct 10, 2003 | 04:08 PM
jiggajiveturkey's Avatar
Car: 88' Firebird
Engine: 2.8L
Baro sensor circuit
My check engine diagnostic test came up with a problem in the "baro sensor circuit". The probable causes the book provided are bad wires/connections going to the ECM or a bad Baro sensor.
So my question, is the baro sensor the most probable cause? What does it do and where is it? Thanks
Old Oct 10, 2003 | 06:18 PM
demonchild's Avatar
sorry for the bad pick , but the baro sensor is the sensor located in this location(circled in white) if you dont know what it stands for it is the barometer sensor and it tells the car the atmosphereic pressure so the fuel curve can be adjusted accordingly.
Old Oct 10, 2003 | 06:19 PM
demonchild's Avatar
i think, and am definently not for sure, that there is a vaccum line going to the sensor. make sure it didnt get dicontected. make sure the harness is snug on it.
Old Oct 10, 2003 | 10:08 PM
Car: 88' Firebird
Engine: 2.8L
I think i found the Baro Sensor but it is not where the book said it would be so i attached a pic to make sure i am on the right track.
Assuming what i am looking at is what i think it is, all the wires and the vacume hose look good. Is this a sonsor that commonly goes out? Is the price low enough that i should just replace it to see if that fixes the problem? Thanks a bunch!
Old Oct 11, 2003 | 05:37 PM
demonchild's Avatar
can you post one a little farther off. im not sure what im looking at. i believe it is around there but a little higher.
Old Oct 11, 2003 | 05:40 PM
demonchild's Avatar
that actually looks like the one, but i would get more advice first because the sensor isnt cheap, its like 50 bucks or more.
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
1nastygta
Sep 24, 2015 08:58 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
gta892000
Sep 16, 2015 12:37 AM
