Car stumbles
Old Oct 11, 2003 | 10:59 AM
black formula's Avatar
Car stumbles
Hi Guys,
I hope someone can help me. My car stumbles when you give it gas. It feel like if I had a carb and its flooded thats what it feels like. This only happen when the car has been running for a while. I did a complete tune up a month ago and I change the fuel injector about a year ago and the stumble does not go away.
I was thinking maybe the coil is starting to act up. Can some one please help me out.
Old Oct 11, 2003 | 12:06 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Sounds like ignition. Check plugs, wires, cap, rotor, ignition coil... It's possible it could be in the distributor as well, but...no real way to check that. No check engine lights right?
Might as well check fuel while you're at it...make sure you've got decent fuel pressure.
I'd do a vacuum test also. A vacuum leak can make you surge, stumble, and miss.
Old Oct 11, 2003 | 01:21 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
is your tps and iac adjusted correctly?
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
squiggy2
Aug 9, 2015 09:30 PM
