O2 sensor, should I use teflon tape or anti-seize or nothing at all?
Old Dec 2, 2000 | 12:19 PM
theformula's Avatar
Im installing a new Bosch O2 sensor in my headers, should i use some sort of sealant?
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
Old Dec 2, 2000 | 12:34 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Never use any type of chemical on the 02 sensor. That will mess it up. Don't use anything. Just screw it in. Teflon tape would last maybe 10-15 seconds before it burns away.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Pino91Formula's Avatar
No they come with anti seize on them allready , just pull yours out and install the new one
Old Dec 2, 2000 | 05:42 PM
Vader's Avatar
Pino is right - but they don't come with ENOUGH anti-seize. Teflon would burn away almost immediately, as Stinger said, and that would be good since the sensor must be grounded to the pipe.
Don't worry about sealing the thread with a sealant, since there is a gasket washer installed on the sensor just like gasketed spark plugs. Just apply a little extra anti-seize to the threads only and screw it.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 2, 2000 | 06:54 PM
ede's Avatar
ede
i like the lead based anti seize instead of the silver kind. little harder to find but i think it works better.
-=ICON MOTORSPORTS=-
1st & 3rd
gta892000
Aug 11, 2019 11:16 AM
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
wstephan96
Sep 25, 2015 04:28 PM
