hatch pull down motor
Old Oct 22, 2000 | 11:21 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
My hatch sometimes goes down, and when it starts to itll start making a buzzz then u push on the hatch and it goes down some more etc.. now the hatch comes up ..like nothings holding it down..but it doesnt fly open yet (thank god) any ideas? how much to replace? thanks
88 Firebird 2.8
MODS (either coming or on):
Flowmaster Cat Back, Random Technologies Cat, 3" intermediate pipe, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6a, B&M Shifter, Transgo Shift Kit, Cold Air Induction, NEXT MOD: 5 speed...(torque convertor going so 5 speed a better idea) ..Then peeling and cracking paint..
Old Oct 22, 2000 | 11:24 PM
Jester's Avatar
Mine just went ot last week. I took it out and welded the latch in the down position. Now I never have to worry about being stuck with a trunk that won;t close again
Old Oct 22, 2000 | 11:37 PM
lol
Id do it if i didnt have to get back there...but im always back there so...
88 Firebird 2.8
Old Oct 22, 2000 | 11:40 PM
Jester's Avatar
Oh it opens just fine...it's just the remote switch doesn't work. and it doesn;t do that gimpy "raise up and pull back down" thing anymore..it just latches in the down spot.
Old Oct 22, 2000 | 11:45 PM
ah **** i see what u did....hmmm....damn i dont have a welder anymore
it still operates fine and everything? that damn pull down thing is useless anywayz
88 Firebird 2.8
Old Oct 23, 2000 | 06:22 AM
DEEPSOUTH90RS's Avatar
I KNOW THAT DAMN THING ALL TOO WELL. I LOOKED IN NEXTGENPARTS.COM, ANT A NEW PULL DOWN IS $400!!!!!!!! MINE ONLY WORKS WHEN IT WANTS TO, AND THE SWITCH TO MAKE IT GO DOWN STICKS TOO.THEN IT WILL LATCH,BUT WONT GO DOWN! I THINK THAT YOU CAN FIND A DECENT ONE AT A SCRAP YARD IF YOU LOOK(I HAVENT YET,BUT THIS IS LOWER SLOWER MISSISSIPPI,EVERYTHING IS HARDER TO FIND DOWN HERE!)HOPE THIS HELPS!!
90 RS
T-TOPS
3.1 V6
RUNS STRONG AT 187,650
ON ORIGINAL ENGINE
Old Oct 23, 2000 | 08:43 AM
hdtripp's Avatar
Car: 89 Formula
Engine: 5.0L tpi
Transmission: 7R400
Mine broke about a year ago. The plastic housing mounting broke loose. I think it was about $150 for the housing itself. I think it was about $400 for the whole assembly. It wasn't hard to swap out and the pull down works fine now. The welding idea sounds good though, I never did understand the purpose of the pull down.
H.D. Tripp-89FormulaWS6 w/5.0L TPI, Street & Performance Chip
Old Oct 23, 2000 | 09:37 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I believe the purpose of the pull down trunk, is so you dont have to slam the trunk hatch. Plus you dont put any pressure on the foam wing (it wont crack as much) so I have been told. Mine dont work either, I think its the relay, which runs about 40$ (Canadian funds).
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Oct 23, 2000 | 10:56 AM
freeze92's Avatar
The parts to repair the latch are available from GM for about $40. You probably need the housing and the plastic gear. Take it out and go to the local dealer. If they are not willing to help, let me know. I can get you the part numbers, but it will take me a couple of days.
Old Oct 23, 2000 | 09:48 PM
Hey jester u gave me an idea i did...drilled 6 holes and pop riveted the dame thing with some 5/32" rivets...works great...
88 Firebird 2.8
Old Oct 23, 2000 | 10:01 PM
Jester's Avatar
hehe glad I could "help" ya out man
Old Dec 2, 2000 | 01:38 PM
BigH's Avatar
[QUOTE]Originally posted by freeze92:
Hello Freeze! Do you know if a part number exists for the GTA trunk pulldown motor plastic guides. My guides are shot to hell and don't allow smooth up/down travel, think that's why my motor burned up? Thankss
Old Dec 3, 2000 | 12:04 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
Hey guys just in case you are interested I
just seen two or three of those hatch pull downs on Ebay, one was brand new and they went for about $60 TO $100, wouldn't hurt to check there once in a while
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle, 4 wh. disc brks.
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
