Does this cam sound too big, or ok?
Check out my mods, its on a SD 305 TPI
COMPETITION CAMS CAMSHAFT SPECIFICATION SHEET
PART # 08-304-8
GRIND NUMBER: CS 266H-R14
ENGINE:CHEVY SM BLK 305-350
GROSS VALVE LIFT .500 .510
.006 TAPPET LIFT 266 276
VALVE TIMING OPEN CLOSE
AT .050 INT 5-BTDC 35 ABDC
EXH 48 BBDC 8-ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 110 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 210 220
LOBE LIFT .3330 .3400
LOBE SEPARATION 114
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
PART # 08-304-8
EXH 48 BBDC 8-ATDC
INTAKE EXHAUST
LOBE SEPARATION 114
'92 Formula
305 TPI 5speed
1LE package
depends on what you're doing with it. for the street i think i'd look at something smaller. also depends on what you're doing to it in the future.
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
The cam will be the last mod (with the prom of course). Theres a guy on this board with similar mods to me that put this cam on and gained 5tenths on his 305.
'92 Formula
305 TPI 5speed
1LE package
'92 Formula
305 TPI 5speed
1LE package
ambainb
Apr 25, 2016 09:21 PM
