aluminum tube
Old Oct 13, 2003 | 11:48 AM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Axle/Gears: Stock round ones
aluminum tube
what is the purpose for the aluminum tube that runs from the passengerside valve cover to the intake just in front of the throttle body and is it filtered this is on a 173mp '86
Old Oct 13, 2003 | 12:19 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
That's your PCV return. It's got a filter element sitting in the fitting that goes into the valvecover.
The passenger side valvecover has the actual PCV valve...that circulates air in through the crankcase, and it's vented back out the driver's side, where it's filtered, and vented back into the intake to be reburned. Brings emissions up.
Old Dec 16, 2003 | 08:47 AM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Really?
So you are saying that there is a filter in the grommet housing that connects the tube to the valve cover and it is on my passenger side
Originally there was a lot of buildup oil resisdue inside the carb and plenum. Leading to small problems that I have tried to clean up.
Old Dec 16, 2003 | 09:22 AM
Nixon1's Avatar
I'm a little mistaken here...actually there is no filter in there. I was thinking of my Mustang, which has a screen, but from what I was told, these cars don't.
And built up oil residue in the carb? What carb?
Old Dec 17, 2003 | 08:42 AM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Doh Throttle body Throttle body I keep telling my self Throttle body
Old Dec 18, 2003 | 12:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm afraid you've got the flow direction backwards there. The PCV valve is hooked up to the vacuum side of the intake, so it pulls a vacuum on the crankcase.
The aluminum tube is a filtered air crankcase inlet. It's at atmospheric pressure (down-stream of the air filter but up-stream of the TB), so the vacuum being pulled on the crankcase by the PCV valve pulls fresh clean air into the crankcase through this tube. This keeps combustion gases that get around the piston rings from building up in the crankcase. The "burning" takes place when the gases going into the intake manifold hit the cylinders.
Old Dec 18, 2003 | 08:54 AM
Vader's Avatar
That's O.K. When I read "Aluminum Tube" I though he might have been performing deuterium processing for plutonium extraction...
Old Dec 18, 2003 | 10:01 AM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
That would explain why the IAC housing was carbonized!
Now the finiky girl doesnt want to start again this morning I think I have a weak spark!!! Back to the grindstone soon soon I tell ya I'll have it runnning smooth Nothing like new parts!!!!!!!!!!
Old Dec 18, 2003 | 11:03 AM
Nixon1's Avatar
Thanks man... Damnit I've skimmed this post 50,000 times and I can't believe I never noticed my own typo. I basically told him the PCV valve and PCV return were both on the pass. side. That must've been a bit confusing!
Old Dec 18, 2003 | 02:20 PM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Not really that is why i used photos!!! u now the downfall is that it ran for twenty mins the other day and now she wont start ahhhhh
Perplexed
Stryder
Old Dec 18, 2003 | 05:21 PM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Finally Finally!!!!!!!!!!!!!!!!!!!!
Bad Plugs was todays lesson! Why? U Jest. Because Chemtool oil residue and crankcase carbon vapors make a nice glaze when u run for twenty mins and shut it down(hot plugs) and one more cold start then today really bad I even sandedd the plugs that wont work cause the ceramic has a nice glaze (the spark shot from center to edge of course this is bad so off to the zone and Kick #ss running smooth also opted for new wires
I would like to thank all of you all for ur much needed thoughts. This has been a long series of threads (search my threads) all related to this problem and now the finall finish Once again
ThirdGeneration ROCKS
Later
Stryder in car moving
P.S. MERRY CHRISTMAS
Old Dec 18, 2003 | 05:24 PM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
And a HAPPY NEW YEAR!!!!!!!!!!!
Linson
Oct 24, 2025 02:00 PM
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Bigold4x4
Sep 28, 2015 05:21 PM
