Crane 2032 Cam
Old Nov 30, 2000 | 12:53 PM
Pat Hall's Avatar
Crane 2032 Cam
I asked some questions about this cam in Eddie 89 T/A's post a few days ago, and no one has had anything to say in response. I was wondering if this cam is enough of an improvement over a stock cam to justify the cost of it. I'm rebuilding an L98 right now,and my goal for now is to make it a little hotter than stock without having to change the chip. I figure I can always add 1.6 rockers in the future if I decide to upgrade my chip. Does anyone have any good or bad comments about using this cam? If I remember right, the specs are 214/220 duration@.050;452/465 gross lift w/1.5 rockers, and 112 degree centerline. Let me know what you guys think.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
[This message has been edited by Pat Hall (edited November 30, 2000).]
Old Dec 1, 2000 | 07:09 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The 2032 is a very nice piece. I wanted a cam that would work normally aspirated as well as under boost, AND emissions legal. I use 1.6 rockers and very pleased with the results.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Dec 1, 2000 | 08:06 AM
theformula's Avatar
Thats the cam you want. A lot of guys go too big with the duration and valve lift. The specs of that crane cam will work great.
You may lose a little low end with the 112* lobe separation. Check out Comp Cams 08-304-8.
It's a pretty mild cam too and has the lobe sep of 114*. Car will idle better and still retain all of it's vacuum.
Oh yea if you plan to use forced induction, your lobe sep HAS to be 114* or higher. I've seen a lot of LT1/LS1 guys burn out their engines in under a year from using a supercharger or nitrous with their aftermarket cams at (112*).
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...Comp cam (i still have to install it )
[This message has been edited by theformula (edited December 01, 2000).]
Old Dec 1, 2000 | 02:17 PM
Willie's Avatar
There's a little bit more to it than just LSA. The 2032 is the perfect cam to use as an example for a cam with <114 LSA, but is perfect for a blown application. Yes, it is true that is has a 112 LSA, calculated by adding the maximum lift of the intake @ ATDC (107 deg) and maximum lift of the exhaust at BTDC (117 deg) and dividing by 2>>> (107 + 117)/2 = 112.
To calculate overlap, which must be minimized in a blown application, look at when the exhaust valve closes (-7 deg BTDC) and when the intake valve opens (0 deg BTDC)-- seven degrees of "non-overlap" period. Therefore, this cam has no overlap. In fact, if this cam were ground on a 114 LSA, the exhaust valve would close at -5 deg BTDC -- still five degrees apart from any overlap. Therefore, this cam is perfect for a blown application.
In summary, NEVER look at only LSA. Always get the valve timing specs.
If there is any doubt to what I state, call Crane cams (904.258.6174) and ask for yourself. My information was received directly from Crane.
Willie
[This message has been edited by Willie (edited December 01, 2000).]
Old Dec 1, 2000 | 05:14 PM
Pat Hall's Avatar
No worries Willie, I trust what you say on the lobe separation. Makes perfect sense to me. You definitely don't want any overlap when boosting an engine. My main concern about this cam though was how big of an improvement it is over a stock one, and whether or not it would give the stock prom fits. The other cam I've been considering is the ZZ3 cam, or maybe the comp cams 08-304-8 that Formula mentioned. One thing is for sure, the camshaft is always the most perplexing thing for me to try and decide on when I'm rebuilding an engine! Especially considering the cost of the roller cams. Does anyone have any input on these other two cams versus the 2032? By the way, just to remind everyone, it's going in a L98 350 with TPI. I really appreciate everyone's help and suggestions, I think I'm starting to get my decision a little more narrowed down! Lol.
Old Dec 1, 2000 | 06:35 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
2032 results:
I just built up a 305 with a stock TPI intake, ported stock heads (9.8:1 CR), a 2032 cam, and 1.5:1 full roller rockers & dropped it into an '84 Berlinetta. The motor drives a 700R4 with 3.42:1 gears & GM posi behind it - it runs low 14's @ 3100 ft (high 13's corrected).
Tim
Old Dec 1, 2000 | 11:11 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i also have the 2032 cam in my 305, i havent really played with it but it seems pretty awesome, althoug i've added S/R torquer heads at the same time, the cam says to use 3.73's or lower, i have 3.23's but going to 3.73's.
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Dec 2, 2000 | 07:56 AM
theformula's Avatar
pat, the reason I recommended the 08-304-8 is because a guy i know (87 305 TPI 5speed all bolt ons) had trouble breaking 13s. He ran a best of 14.4 with every bolt on imaginable. WHen he got the comp cam he ran a 13.9@99mph
You might be able to get away with its big brother the 08-305-8.
I stand corrected Willie about the LSA
'92 Formula
305 TPI 5speed
1LE package
Old Dec 3, 2000 | 11:09 AM
JeffP's Avatar
Is that a roller?
Old Dec 3, 2000 | 12:39 PM
theformula's Avatar
yep
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
