How much did you spend on you're engine?
Old Oct 14, 2003 | 02:40 AM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Like the title says.
I'm going to build either a 355, 383, or 400 soon. Wan't to see how much you all have payed on you're build up.
Add how much hp and tq you are pushing too if you don't care.
-Jensen
Old Oct 14, 2003 | 09:41 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I took my 2bolt main 400sb out of my '71 chevy p-up, rebuilt it and stuck it in my 85Z28. Had it bored .030 over etc. etc. It only cost me 1000 dollars cuz my good friend is a machinist/mechanic who builds racing engines. It is at 500hp right now with all the mods. My best guess is that I have spent probably $2500 total. However, if you dont know anyone who can build your engine cheaper, my mechanic told me he normally charges 2500 dollars to rebuild that type of an engine with it being bored out etc etc...
Old Oct 14, 2003 | 10:12 AM
NotDaZ's Avatar
I just rebuilt a 350 from an 80' pickup. It was hot tanked, bored .30 over, had the heads redone and shaved along with a rebuild kit, pistons 10:1 flat tops. All that was done at the machine shop cost me `$1,000. That included the rebuild kit w/pistons. I bought the block from the local junk yard and it cost me $100. Then all the other things....new intake, hoses, plugs, wires....To make the swap it cost me ~$1,500.
I also sandblasted and painted the engine bay while the engine was out...That is not included in the $1,500.
Scott
Old Oct 14, 2003 | 10:50 AM
jimmy_mac's Avatar
re-manufactuered L-98 short block from champs auto was $900
that included a 150 or 200 dollar core chage since I had a 305.
rebuilt 416 305 heads with bigger valves, springs, screw in studs, ect... $350.
replaced L98 cam with xe269HR comp cam used on ebay $160.
Gaskets and misc crap added up quick, probably over 200 bucks. I re-used a lot of things like rocker arms, balancer, etc.. but still ended up spending close to $2000 I bet.
That combo got me a 14.80 at 97 mph with an open differential. Probably could have gotten a much lower e.t with posi.
since then I have spent and addtional $700 on vortec heads with bigger valves, springs, and appropriate manifold (performer rpm I got on ebay for 65 bucks) and have not had at the track. But the power increase is very noticeable. My mph should go up considerably.
So don't skimp on the heads.
Old Oct 14, 2003 | 02:34 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
$1500
Including buying the engine. I think the 400 is the best bang for the buck.
Old Oct 14, 2003 | 03:03 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
hey tom400cfi
your sig says 75 lb/hr injectors...
is that a typo? isnt that astronomically high?
i dont know a whole lot about it, but i see numbers like 19 or 25# ive never seen 75#
Old Oct 14, 2003 | 04:55 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
With Cross-fire injection, there are only 2 injectors, not 8.
75# may even be a little small for a 400 depending on cam, heads, etc.
Old Oct 14, 2003 | 05:26 PM
Engine: LT1, L400
What AJ said.
Old Oct 14, 2003 | 06:40 PM
plain82's Avatar
So far, around $700.
355, balanced and assembled: $400
Performer intake: $40
600 CFM Performer carb: $100
Rebuilt heads: $120; $50 for the heads, $70 for the work.
Probably won't use these heads, though. I'll have my other set redone.
I estimated some of the costs, as I traded sevices for the work. Being an electrician has advantages sometimes.
Old Oct 14, 2003 | 08:19 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
DESCRIPTION PART# PRICE Short Block Long Block
Heads 195cc AFR-1035 $1,450.00
Main Studs ARP-234-5501 $51.95
Head Bolts ARP-134-3601 $49.95
Oil Pump Stud ARP-230-7002 $6.50
Oil Pump Shaft ARP-134-7901 $13.95
Fuel Pump Pushrod ARP-134-8701$14.95
Mechanical Fuel Pump
CRT-M4891 $61.95
Main Bearing MS1038P $27.00
Rod Bearing 8-CB663P $27.00
True Roller Timing Chain CLO-9-3100 $67.95
H-Beam Rods CRS6000B3D $335.09
Elite Air Cleaner EDL-4207 $49.95
Solid Lifters VT1992-16 $45.00
Cam Bearings 1235M $19.00
Head Gasket FPP-1014 $63.90
Intake Gasket FPP-1205 $13.95
Rear Main Seal Align Bored
FPP-2909 $19.95
Roller Rocker CSP-1001 $182.95
Flat Tappet Mechanical LUN-280/284F10 $169.00
Oil Pump Pick-Up Screen
MIL-18311 $34.95
Milodon Street/Strip Oil Pans MIL-30900 $134.95
Diamond Stripper Windage Tray MIL-32250 $74.95
Windage Tray Stud Kits
MIL-81150 $41.99
Oil Pump MEL-M55 $15.95
Engine Magnet Kit
MOR-22710 $13.95
Oil Pump High Press Spring
MRG-26 $3.95
Degree Wheel MRG-6120 $29.95
Rear Main Seal/Align Bored MRG-1962 $19.99
Brass Freeze Plugs SBC 400 $14.95
9000 Internal Ballance Crank 400-3750-6000 $222.50
Bore w/ deck plates (.040) $120.00
Install Cam Bearings $25.00
Deck (.000) $150.00
Align Honed Mains $135.00
Tap Starter Bolt $25.00
Tap 3 Oil Hole $15.00
Tap Deck Water Holes $100.00
Hone Cyclinder $60.00
Balance Rotating Assembly $225.00
Mount Pistons to Rods $40.00 Pro Tru Forged Pistons
PT020H4 (0.040) $419.00
Engine Assembly Lube
VHT-SP701 $7.95
TOTAL COST $4,400.07
Old Oct 15, 2003 | 05:03 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
ohhhhhhhhhhhhhh, thanks!
Old Oct 15, 2003 | 09:04 PM
EvilCartman's Avatar
Car: '82 Z28
Well, just added everything up and it comes to $5247 for parts and the machine shop's quote. Taking everything tomorrow to the shop. This is for a 355 that'll be pushing about 500 hp 450 tq.
Old Oct 15, 2003 | 10:06 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I bought my 350 from a totalled truck with 30k on it for around $600. It already had ported heads and a 3 angle valve job(or so the guy said I have no proof).That engine alone got me a 14.6 with headers and exhuast , and a 670 cfm throttle body.All together I spent about $1200 for everything for that setupincluding the equipment I used to swap the motors.now I have a few more things I want to add on . I am looking to build a new engine soon.
Old Oct 15, 2003 | 11:16 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
2,100 383 short block
400 cast heads
120 weiand team g intake
40 m/t black crinkle valve covers
70 stewart stage 1 water pump
35 pushrods
105 roller rockers (1.6/1.5 split pack)
80 on bolts
20 two inch carb spacer
160 holley 750 (new)
20 holley annihilator hei module bypass
16 msd hei external coil adapter
75 oil pan and pickup
35 felpro gasket set
20 proform black timing chain cover
10 valve cover t-bars
there is a few more but they were taken off my other 350 motor. to bring a total of $3,306 and its not quite done yet.
Old Oct 15, 2003 | 11:33 PM
StealthElephant's Avatar
Car: 87' Iroc
2 Bolt 350 already bored .030 125$
LT1 rods Free
Summit engine rebuild kit w/ 10.7:1 Pistons 325$
Complete 350 truck motor 100$ (Crank, Oil pan, timing cover etc)
Cloyes double roller 67$
Protopline Vortecs complete 615$
Edelbrock performer 150$
Comp cams XE268H + lifters 145$
670 street avenger 350$
ARP head studs 55$ (they aren't leaking...ever )
accel HEI distributor 191$
probably another 500$ worth of random crap, I used the junked 350 for any extra bolts I'd need. only thing I really spent $$ on was the induction/ignition
I spent about 2000$ for all the engine parts and machine work. Not counting another 1000$ to get the engine installed and running...
my next engine i def want to use all brand new parts....cause going used is just a PITA, sure I saved probably about a 1000$, but i also caused myself hours of pain and suffering....I tried 3 points distributors (including 1 new one) before I just got that really nice accel piece....car wouldnt' even run until that accel piece went in.
Old Oct 16, 2003 | 10:49 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
from carb to oil pan... bout 3700 bucks.
355, vortec heads, forged crank, and pistons, polished X rods
about 1800 into the 700 R to hold up..
couple hundred int suspension stuff.
11.96@113.5
Old Oct 18, 2003 | 11:31 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I built a 355 ( L98 based )
L98 .....oil pan to the plenum ....ECM injectors sensors , MAF ......just needed a rebuild .........................................700.00
Edlebrock Hi FLO intake and runners ( used ) ..................900.00
ZZ4 camshaft .................................................................... 50.00
CLeaning and flowmatching injectors ( a MUST ) ..............250.00
Magnum roller rockers 1.52 ...............................................350.00
30 thousands overbore .....polished the crank , magnaflux
and hot tank the block , put in screw in studs minour bowl
work 3 angle valve job , assembled with all new bearings
seals, oil pump , forged 10:1 pistons and total seal rings
balancing........................................................................ ....2100
so like .................................................................................4350CDN
Jake_92RS
Jan 28, 2020 10:37 PM
onefreakz
May 14, 2018 12:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
