Wonder Bar??
Old Dec 1, 2000 | 10:37 PM
cobrakiller1989's Avatar
Wonder Bar??
Has anyone ever heard of an "IROC wonder bar"?? A friend of mine told me about it and i was trying to find out what it is. also is it in an 88 IROC
Old Dec 1, 2000 | 11:12 PM
R.O.B.'s Avatar
Yea,
check out the suspension board for more info. Its a bar located just under the swaybar in IROC's only (maybe Z28, but no pontiac's). The bar is supposed to connect the lower framerails, and is said to be a nice addition.
Rob
'86 TA 305 TPI
Old Dec 2, 2000 | 09:51 AM
Thanks alot ROB
Old Dec 2, 2000 | 07:05 PM
Pat Hall's Avatar
I put a wonderbar on my 89RS. I got it off an 88 IROC. It's easy to spot once you know where to look. It bolts in the same place as your front sway bar, right where the U shaped bushing brackets for the sway bar bolt up. You'll see a thin bar running parallel with the front sway bar if you already have it on your car. They're a piece of cake to install. All you have to do is unbolt the U shaped brackets and drop your sway bar down. Put the bar in place, put the sway bar back up to hold it in place, and tighten the bolts back up. Only took about 10 minutes to do on mine. The car did feel a little stiffer on corners after I put it on, so I guess it does make a bit of a difference in the handling.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 2, 2000 | 08:28 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
U f_cker.....
Eric Natzke
91 Firebird 305 TBI (ZZ5 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Dec 4, 2000 | 12:54 AM
JPrevost's Avatar
Car: 91 Red Sled
They're a great addition to other suspension work like strut tower brace, springs, struts and shocks. Having 36mm front, 24mm rear sway bars helps a bunch too. If you can't find one then globalwest makes them. I think they upped the price to something like $50, not sure though. It's your call though, but I've hear nothing but good things about it. I have yet to install mine (car sits till it gets it's new engine).
, Jon (91 RS too many mods to list)
Old Dec 4, 2000 | 06:44 AM
MikeS's Avatar
..and GM sells them new for like $35 if you want to go that route.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
