internal vacuum leak
Old Oct 14, 2003 | 06:00 PM
88gtagearhead's Avatar
Hi, on my friends car, a 94 z28, his mechanic thinks that he has an internal vacuum leak. He thinkgs that the engine is suckin air from the lifter valley, whether through the head gasket, or the intake manifold gasket he doesn't know. Is there a way to check for this without taking the manifold off?
thanks
Old Oct 16, 2003 | 05:51 AM
ede's Avatar
ede
vacuum gauge, compression gauge, leak down tester
Old Oct 16, 2003 | 06:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If an engine leaks between the intake and the crankcase, it will suck in oil and smoke like a freight train.... a very common cause of mystery smoke in a new motor actually.... if it isn't smoking, it probably doesn't have that problem.
Start by posting the engine's symptoms instead of someone's wild guess about what's causing whatever it's doing, you might get some useful pointers about what to look for.
86IROC112
Nov 27, 2015 09:54 AM
86maro_252
Oct 10, 2015 06:52 PM
84redta
Sep 19, 2015 09:58 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
