new parts new problems
Old Oct 14, 2003 | 07:02 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
this weekend i put new the new springs, shocks, endlinks with poly bushings, lca's, lca relocation brackets, and panhard bar on my car. it handles great, but now i have a loud humming/whining noise when i hit crusing speeds of 35 and above, it seems to be the loudest when i am on the gas at those speeds, if i let off the gas it gets much quieter, but under acceleration it is louder. I think my car had this noise before, just much much quieter. I'm pretty sure its a drivertrain issue because if i put it in neutral at crusing speeds and rev the engine it doesn't produce the noise. I don't know if it is a "bad" noise, i just can't figure out what accounts for it. I don't think poly bushings or the lower springs would account for it.
any ideas?
Old Oct 15, 2003 | 09:11 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Rear going bad? The poly bushings probably just made more of the noise transfer the body of the car making it sound louder. That’s my bet.
Old Oct 15, 2003 | 09:24 AM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
Mine makes the same noise. It sounds like the rear end to me to. Mines been doing it since I swapped rear ends in the car about 20k miles ago.
Old Oct 15, 2003 | 04:49 PM
mgilorma's Avatar
Car: 90 RS
yeah it is weird, the more i listen to it the more i find out about it, for instance, it is loudest between 40-50 mphs, so if it is the rear, what actually causes this noise?
Old Oct 15, 2003 | 09:48 PM
Car: 87 Trans Am
Mines worse around 40-50mph also. I think it's from improper gear setup when gm put these things together.
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
