Blower motor hitting something?
Old Dec 1, 2000 | 06:20 PM
84FTA's Avatar
I haven't seen the inside of the blower motor. I'm going to pull the one from my other car tomorrow and put it into the T-top car. It makes a horrible sound like it's hitting a shroud. It's probably one of the only things i have left to do on these cars....guess it's about time. Anyone else ever have this problem? Do I have to pull apart the dash or just pull the blower motor?
Thanks.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
Old Dec 2, 2000 | 01:32 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The blower motor bolts on from under the hood. I think there are 7 or 8 screws holding it on, and one of them has a connector for a ground wire. Pretty easy to change out on about any GM product.
The sound could be a balance problem with the fan. It is a cage type blower, similar to a furnace fan, and a new one is usually balanced out of the box. the whole deals is pretty cheap to replace, I think I paid like $35 for the last motor and fan blade that I replaced (I'm guessing here, it's been a while!)
It could also be in the heater box a bit crooked and be hitting something. I've had that happen, too.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
[This message has been edited by JP84Z430HP (edited December 02, 2000).]
Old Dec 2, 2000 | 11:16 AM
Vader's Avatar
84,
I've had the same situation more than once. Removal of the blower assembly is really a five minute job. Once you get it out, any damage should be apparent. Ususally, the noise is caused by a dry bearing in the motor of debris in the housing, like dry leaves, etc. Don't be surprized if you find the better part of a maple tree in there...
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 2, 2000 | 09:39 PM
84FTA's Avatar
Thanks for the help. I went outside and took the parts off the hardtop today to switch them over to the T-top car. Started working on the rear brakes and before I knew it was dark. The housing isn't cracked, however the car did sit for 3+ years and had tons of leaves and debris everywhere else in the engine bay. Guess I'll find out tomorrow.
Old Dec 4, 2000 | 02:43 PM
84FTA's Avatar
Not a maple tree in there but sure enough was organic. I found two acorns looking to grow an oak tree. Plus a couple handfuls of insulation.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
