big inch small block ?
Old Oct 14, 2003 | 11:20 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
has anyone built one ? 420 to 454 c.i. small block. i am thinking about it for my new engine, and it needs to be able to handle a large shot of nitrous. i plan on touching into the 9s in street trim. i was only in high 10s this year at 130 , and my friend just ran 10.08 in his 86 with a 406 and 200 shot, so he will be in the 9s next year . also we live at 4800' eleavation
mike
Old Oct 15, 2003 | 08:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
yes
Old Oct 15, 2003 | 01:21 PM
BILLY SMITH's Avatar
Originally posted by RB83L69
yes
for the money invlved your gonna spend i'd go with a big block if its a drag car and not gonna see much street ...build a 481 or a 511 flat top with merlin oval ports and a shot of gas (nos 200-250) should get you there
Old Oct 15, 2003 | 10:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
For what its gonna cost, just build a 454" big block. Cheaper, faster, and looks hairier.
For the record, Ive heard of small blocks over 480".
Old Oct 15, 2003 | 11:17 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
if i had a big block available i would go that way . i have always run BBC's in the past . this is my first try at small blocks. as you can see from my sig i got a decent set up (i think) just need a new short block and trying to figure out what to use to get to where i want.
thanks for your opions
mike
Old Oct 16, 2003 | 01:09 AM
mike
yes i agree after lookin at sig lots of good stuff to lay around .........i would buy a dart little m block and a scat 4340 forged steel crank and with the other parts you got , i would also get some j&e pistons and build a 434
Old Oct 16, 2003 | 08:54 PM
BADDEST305's Avatar
Car: 1991 z-28
Engine: 434--654hp---601 torque
Transmission: ATI POWERGLIDE
Axle/Gears: mose 9" / 411 gears
i did'nt build it but had it built by shafiroff racing engines in long island. 434ci, motown block,callies crank,lunati rods,dart intake,demon 1090 carb, dyno'ed at 654 hp 601 lbs torque to the flywheel just finished the install and hitting the track next week to se how it runs
Old Oct 17, 2003 | 02:17 PM
THOSE MOTORS WILL ROCK.........GOOD LUCK
Old Oct 17, 2003 | 11:53 PM
jeremy178's Avatar
Car: '89 Camaro RS
I agree, those motors are gonna rock you guy's worlds upside-down
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
