Lots of cam installation questions....
Old Dec 4, 2000 | 03:49 PM
Dan87IROC-Z's Avatar
These are concerning the installation of the LT4 HOT Cam in my 87 IROC with the L98. I have never done an in-car cam installation before, but I do have a great deal of automotive knowledge, so I do feel comfortable doing this just so long as I can get a few questions answered.
1. What special tools will I need to do the installation?
2. Also what sort of lubes and additives will I need, and how much will this cost?
3. Will I need to drop the oil pan to pull off the timing chain and timing chain cover, if so, how do I do this?
4. Is it nessassary to get to the lifters when doing this, in other words, will I need to pull the TPI off?
5. What all gaskets will I need to buy, and how much should I expect to spend on this?
Thank you, and I am sure I will have more along the way.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 4, 2000 | 04:28 PM
ede's Avatar
ede
torx sockets, dmaper puller and installer,you may or may not need to drop the oil pan. i've got luckey before and never had to, cut the lip off the back side of the timing cover will make it easier to get back on. yeah you have to pull the tpi stuff to pull the lifters. you don't have to replace roller lifters when you do a cam swap. you'd need a intake and timing gasket set. i use lubriplate engine assembly lube on roller cams. i'd break the cam in with 30w oil.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 4, 2000 | 04:47 PM
Pat Hall's Avatar
[This message has been edited by Pat Hall (edited December 04, 2000).]
Old Dec 4, 2000 | 04:48 PM
Pat Hall's Avatar
[QUOTE]Originally posted by Dan87IROC-Z:
[B]These are concerning the installation of the LT4 HOT Cam in my 87 IROC with the L98. I have never done an in-car cam installation before, but I do have a great deal of automotive knowledge, so I do feel comfortable doing this just so long as I can get a few questions answered.
Since it's a roller cam, it doesn't really require any special lubes because it doesn't have to be broken in. I'd just use a good thick oil like 20w-50 to lube up the lobes and the main journals before you put it in. As far as special tools, you'll need a harmonic balancer puller, and if you're replacing your timing chain and gears with a new set, you'll need a two or three jaw gear puller to remove the old gear from your crankshaft snout. By the way, a pipe that fits over the snout works great for driving the new gear on. I use an old intake manifold breather tube, it's the perfect size for this. If I were you, I'd just loosen the oil pan bolts and carefully pry it down a bit to allow you to pull the timing cover off. As far as gaskets, you can buy a timing chain set from Fel-Pro that includes the timing cover gasket and crank seal, and water pump gaskets. You'll also have to remove your TPI to change your cam, so you'll need the gaskets to reassemble it, and the intake manifold to head gaskets. You have to pull the lifters out to change the cam, otherwise, they'll drop down when you attempt to pull your old cam out. Since I haven't changed the cam in the car on one of these, the only gray area I have about it is if you can clear the A/C condensor when pulling the camshaft out. It's easy to remove the radiator, but I don't know how easy it is to move the A/C condensor out of the way without disconnecting the lines. This concerns me on my car because the A/C works great, and I'd hate to have to discharge it. Good luck on the install, and hopefully someone on here has a good suggestion on what to do about that condensor core.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 4, 2000 | 06:14 PM
Guest
Guest
Posts: n/a
I moved the condenser out of the way on my 85 to replace the cam. You will also need to remove the braces that run across the front of the radiator, and maybe the support thats in front of that as well.
Old Dec 5, 2000 | 11:33 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Other than whats been suggested above, I'd also suggest making up a cam installtion tool...otherwise you'll get the cam about 1/2 way in, and it'll start dragging over the bearings and possibly nicking them up.
I don't know how much room you'll have to work with when installing a cam with the motor still in the car, so you may want to eyeball it ahead of time.
Old Dec 5, 2000 | 11:56 AM
rsilver's Avatar
I understand you can move the Ac condenser out of the way, but I also understand that doing so may cause certian fittings to leak...........bob
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You will have to remove the condenser. However, you don't have to unhook it; you can move the condenser and compressor together off to the side without busting it open.
You will have to remove or severely sodomize the vertical brace below the hood latch in order to have enough room to clear the cam. I would recommend removal. Use a cam gear as a "handle" to control the cam as you slide it in and out, to avoid damaging the bearings. BTW a gear on the cam will not clear the bracket no matter how severely you sodomize it.
Old Dec 6, 2000 | 01:06 AM
Thanks guys, any other stuff I need to know?
L98 TPI 350 (5.7L)
Frozer!!!
Jan 19, 2024 04:55 PM
anesthes
Mar 10, 2016 10:35 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
drathaar907
Aug 6, 2015 04:20 PM
