I wasn't sure if this should go here or on the carb board, but here goes...
1986 Camaro IROC-Z LG4
I have already removed the rod on the air flaps over the secondaries (the rod limited them to open only 3/4) and now when you step on it the vacuum pulls it open 100%...
I also have an open element on the car, and plan on doing exhaust this Spring...
Anything else? Probably not, but I figured I'd ask...
Stuart S
1987 Trans Am LB9/WS6
1986 Camaro IROC-Z
OEM Posterchild of the soon to be Infamous Long Island Crew
[This message has been edited by Stuart S (edited December 06, 2000).]
Stuart S
1986 Camaro IROC-Z
five7kid
close
Advance the timing a couple of degrees at a time. I've got mine set a 3 degrees now vs. the zero factory setting, makes a big difference in throttle response, believe it or not. I ran it at 6 degrees this past summer, but had to use mid-grade to keep the pinging down while advanced that much.
Look in the tech articles for adjusting the AV. You said you got them to open completely, but didn't say you adjusted the spring to get them to open more quickly. Doing this, and freeing up the exhaust flow may require changing the rods & hanger, and although not "free", isn't that expensive.
An often over-looked "free" mod is keeping the tire pressure up to the proper level.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
As far as the timing, it was advanced, but the pinging was unbelievable!
I run 93 Octane...
I run 93 Octane...
hey whats up?
Heres a cheap mod for ya, call around to carb rebuild shops in your area and see if they can sell you a set of secondary metering rods and a new hanger. I put a DR rod in and a B hanger and my car pulls like a son of a bitch. they make your secondarys have more gas to mix with all that air you got going to your secondaries. But the DR rods might not be right for you, jsut buy lots of rods and play around with it. youll get it right for your car.
later and good luck
keep the stang's far behind u and the cops even farther
later and good luck
I didn't even get a new hanger I just bent the stock one upward slightly and it worked fine. Keep bending the hanger until you start going slower and running rich.
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, Holley Street Dom intake.
Swap it out for an Edelbrock.
Yea Long Island!
-80 Camaro 350, Carter AFB, headers, dual exh, ram air, all sorts of crap
-88 Iroc-Z 350tpi, 3.27 gears, 4 wheel disc, MSD 6a, tpi airfoil, k+n's, white gauges, accel coil, flowmaster, pretty quick
Yea Long Island!
A good wash and wax will help, Then posting a million pics on macs board will make it even faster.
Steve R - where in Westbury are you?? My uncle used to live off of Ellison Ave on Earl St (by the train tracks)...
You ever hit Bellmore or anything? Drop me an e-mail if you want...
Perp - sheddup. I don't post there with those petty immature morons anyways...
Everyone else, thanks for the comments...
Stuart S
1986 Camaro IROC-Z
Stuart S
1986 Camaro IROC-Z
