lost heat at burger king drive thru
Old Dec 4, 2000 | 08:36 PM
chrisfrerick's Avatar
i was waiting in line at burger king for about 7-8 min when my heater began to blow cold air. i thought the ac was on for a minute. i switch it to vent and it still was blowing cold air. the blower motor was on high and it still worked on all speeds. when i got back on the road to about 35 the heat kicked back in. could this be a sticking thermostate. i have a 160 thermo and chip. and allot of other mods. it was about 30 degrees here in ohio today. my car does get warm in the winter after driving a mile or so. my car never gets above 180 degrees on my auto xray scanner. any ideas what happened?
Old Dec 4, 2000 | 09:55 PM
daverr's Avatar
i had this problem with my car it turned out to be the intake gaskets.Check your radiator level.if its low look for the leak,if u dont see any check your dipstick(its looks like chocalet milk,literally).
dave
Old Dec 4, 2000 | 10:02 PM
CamaroMike's Avatar
Check the coolant level and if you have a TPI or TBI engine check (aaaaa screw it) just change your heater control valve. It's gonna go eventually. Hope this helps!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Dec 4, 2000 | 10:47 PM
mtx28's Avatar
yea, i saw in a magazine the most common problems w/heaters , when they stop blowing air is the control.. replace it for like 20 bucks if i rememebr right (read this in CHP)
Old Dec 6, 2000 | 12:51 PM
Blade's Avatar
What the hell is "chocalet milk" ? ROFL!
Old Dec 6, 2000 | 05:13 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
sounds like either you were low on coolant, or the heater bypass valve closed for a bit becuase you were idling and it didnt have enough vac to hold it open, this could be caused by a vac leak or a bad bypass valve..
Old Dec 7, 2000 | 10:12 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I have the same problem. I posted this a little while ago. www.thirdgen.org/messgboard/Forum7/HTML/003345.html
HOpe this helps
BlueIroc-Z
Jun 9, 2019 03:22 AM
Infested
May 22, 2018 11:56 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Dialed_In
Aug 20, 2015 01:45 PM
djmarch
Aug 19, 2015 12:07 PM
