Need TPS help, non-3rd gen
Old Dec 6, 2000 | 01:09 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I put a new TPS in my 89 ford escort and now it idles good when it's cold, but when it warms up, it idles about 2000rpms.
Anyone have ideas?
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Dec 6, 2000 | 08:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You really wanna hear ideas about an Escort, on an F-Body board?
Old Dec 6, 2000 | 10:27 PM
Vader's Avatar
88,
You could have a 1.8L DOHC, a 1.9L, a 2.3L, or a 3.0L V-6. The setting procedures for base idle are diierent on each one (their "better idea"). If you have a 1.8L, you can adjust the base idle with a stop screw like on a carburetor. If you have a 1.9L, you're screwed - there is no adjustment. A 2.3 and 3.0 are similar, but require a scanner.
For any condition, check for vacuum leaks and binding throttle plates/linkages it the idle is too high.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 7, 2000 | 11:09 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Thanks Vader - I have the 1.9L in there
Escort help from a Camaro board hmmmmm Why not? My 3rd gen does not have a tps so I am not very familar with them, but a TPS is a TPS, just different derivatives.
Miles
88 427 Camaro
www.koolmeister.com
bamaboy0323
Sep 3, 2015 06:07 AM
soarestransam
Aug 24, 2015 08:15 AM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
mdtoren
Aug 16, 2015 05:45 PM
