How hard to put on 1.6 RR?
Old Dec 7, 2000 | 01:48 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
And can ya tell me how?
Old Dec 7, 2000 | 04:57 PM
ede's Avatar
ede
rotate the engine so both valves on a cylinder will be closed. unbolt and replace the rocker. tighten the new rocker nut while you spin the push rod. tighten it untill the push rod stops spinning then go 1/2 turn more. make sure the lifter isn't spinning and making the push rod look like it's still spinning. prelube everything with a quality assembly lube.
-=ICON MOTORSPORTS=-
1st & 3rd
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
squiggy2
Aug 9, 2015 09:30 PM
