Another IAC Question
Old Oct 21, 2003 | 06:21 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
Does my engine have to be warm to adjust the IAC properly.
Also I have an Air Foil would that cause any problems to the IAC, since it blocks the IAC plumbing?
Old Oct 22, 2003 | 12:27 AM
KYL98's Avatar
Car: 1991 Z28
Yes the engine needs to be at operating temp. The airfoil shouldnt affect the IAC's operation, but if you are unsure, just take it off while you set for min air. Be sure to disconnect your EST bypass when you adj the IAC...and then clear the trouble code. Good luck.....
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
